MAF unplugged?
Old Aug 26, 2008 | 11:07 PM
fireman9585's Avatar
Default MAF unplugged?
My 2001 tt quattro was running rough. I thought it might be the MAF, so I pulled off the plug. Now it runs great. Am I hurting anything leaving it unplugged?
Old Aug 27, 2008 | 12:38 AM
moeron7's Avatar
You should get a CEL with it unplugged. Sounds like you have a fualty MAF. May want a new one or at least clean it.
Old Aug 27, 2008 | 01:51 PM
cincyTT's Avatar
I'm make believe
I ran with mine unplugged for a month or so. Thought i had a bad maf and it turned out when i finally got to check it that i have the tip come loose. So its either a dirty or dead maf or a leak post maf
Old Aug 27, 2008 | 02:24 PM
MCPaudiTT's Avatar
If it is a bad MAF, you won't "hurt" anything by running unplugged, but you should get a new MAF and make a repair. If it is a gross leak after the MAF, as cincyTT says it could be, then you risk sucking in unfiltered air, which is not a good thing...
Old Aug 29, 2008 | 01:50 PM
thanks. will get it fixed asap.
Old Aug 30, 2008 | 01:04 PM
IndyTTom's Avatar
I have a Sensor for a 2001 MAF ( just the sensor not the housing) If you want I will let you have it for $50.00 shipped.
I bought it by accident for my 2004 and the 2004 has a different sensor then the 2001's
Old Aug 31, 2008 | 10:53 AM
randomloginname's Avatar
I couldnt get those damn tamper resistane torx plus screws out (no vice grips , no dremel :-P) but I finally cleaned what I could yesterday with the spray, so much gross black particulate matter just ran out, I cant imagine the car wont run better, definitely wprth trying to clean your maf kids.
Old Aug 31, 2008 | 11:01 AM
IndyTTom's Avatar
You can get a specific Torx security bit for that. If you are persistant the Torx bits do come out. I used a standard Needlenose pliers and got a good grip on them and once they break free they come out fairly easily.
Old Aug 31, 2008 | 11:07 AM
Yah, I tried about a million times, I got one of them to turn about a quarter turn, but they kept slipping off. I just ordered a hundred some odd bit set from griots garage that is supposed to have them, it was only ~20-30 bucks, and will be useful for car and electrical tinkering. Not having the right tools is super frustrating :-)
samcrored
Jan 26, 2014 07:33 PM
pmis91
Sep 18, 2011 01:38 AM
trevor51590
B7 Models
Aug 2, 2010 12:10 PM
gabec007
Nov 8, 2008 11:00 AM
LampyB
Apr 4, 2007 06:25 PM
