Manufacturer Control Fuel Air Metering?
So, first I just wanted to start by saying, this forum rocks and has always helped me when I've needed it and I thank you kindly...
So now on to the problem...
Today my check engine light turned so of course I drove over to the nearest Advanced Auto Parts to have them check the code. The code it came up with is P1128 - Manufacturer Control Fuel Air Metering. I'm thinking it could be the Mass Air Flow Sensor possibly, or it could be the o2 sensor? But honestly I don't have the slightest idea...It had been a while since I had changed my air filter so of course I went out and got one of them right away to replace the old and very dirty one so I'm hoping that may have some part of it but I have no clue! Any help would be much appreciated. Thanks again!
Edit: Car is 2001 TT 180hp model.
i was just going to ask this question when i found it hear, i know this is the tt section and i have a b5 a4, but i have that code to and i dnt understand it, no performance issues
Reset the ecu and see if it comes back. That code could be a few things: vac leak, bad o2, or maf. But since you dont seem to be running bad, i would just reset it and see if it comes back and wasnt a random code
i reset the ecu like you said cincy and i have three of them code and they say the same thing as the tread reads,
i have:
1. brand new o2
2. im pretty sure ther is no vaccum leaks
3. i due have the maf sensor from the tt in my a4.
i know this is not my sub forum but i searched and this is where it is.
i have:
1. brand new o2
2000, air, audi, control, escort, fuel, manuf, manufactuer, manufacture, manufacturer, metering, p1128, problem, sensor, tt
