mbc is in
Old Dec 30, 2007 | 07:36 PM
cincyTT's Avatar
I'm make believe
Default RE: mbc is in
you just remove the vac lines to the n75 and use those for the mbc.
Old Dec 31, 2007 | 01:49 AM
TSRgeneral's Avatar
I have an APR chip... is it worth increase my boost levels or is my k03 maxed out alright.
Mods under sig.. thanks
Old Dec 31, 2007 | 12:26 PM
cincyTT's Avatar
I'm make believe
you can run a ko3 into the low 20's psi, but the biggest gain from a mbc is the faster spools and holding boost longer.
Old Dec 31, 2007 | 12:50 PM
John@DNA's Avatar
ORIGINAL: TSRgeneral
Have you datalogged boost? And what figures were you seeing? Check the Compressor efficiency map for your unit to see the exact figures to use.
Old Dec 31, 2007 | 01:01 PM
cincyTT's Avatar
I'm make believe
let me guess, your an engineer or more likely a student? The turbo is out of its efficency with a chip and at the end with 20-22psi. The turbo has been pushed to 30psi w/o issues, but no point in running that since there it doenst produce more power past 22-23psi
Old Dec 31, 2007 | 04:38 PM
achTTung's Avatar
I'm feeling lazy as hell today or I'd consider putting some lines on there.
Old Dec 31, 2007 | 11:11 PM
eliTTe's Avatar
ORIGINAL: cincyTT
Oh the trends i start
I think if you put a pink flamingo yard ornament under your hood, so would everyone else
Old Jan 1, 2008 | 01:21 PM
  #18
cincyTT's Avatar
I'm make believe
i wouldnt go that far. Plus its not me using things that makes others use them, its how well they work compared to the alternatives. Im sure if you gave someone a n75 race valve, this mbc, and a BM, im sure people would rather have the smaller, cheaper, best performer.
Old Jan 4, 2008 | 05:33 PM
  #19
eliTTe's Avatar
got mine today, WOW... bye bye 15psi, hellooo 24 . I am absolutely loving it, this blows the modshack BM out of the water!!! If you have a chip and boost gauge, this is your next mod... period!
Old Jan 4, 2008 | 05:35 PM
  #20
cincyTT's Avatar
I'm make believe
I dont lie now do i? LOL
you totally should throw that input here http://forums.vwvortex.com/zerothrea...09887#44609887
