Misfire....
Old Aug 8, 2009 | 07:21 PM
turbolove's Avatar
Member
Default Misfire....
So my car today decide to turn the check engine light on .... Took it to autozobe. And they told me 3 cylinders are misfiring. Why could this be?
Old Aug 8, 2009 | 09:15 PM
jakej's Avatar
I would guess that you need new coil packs. Replace all four of them. Early tt's had a type of coil packs that failed often. The new version is more reliable.
Old Aug 9, 2009 | 06:00 PM
turbolove's Avatar
Member
I just replaced them and put new spark plugs I chnged 3 of them about 4 months ago and there's 3 cylinders that are bad ..... Gotta get them checkEd...
Old Aug 10, 2009 | 05:47 PM
jakej's Avatar
If you replaced them because it had the same problem before, it's likely the same cause that made them fail again. Example: running rich and following out spark plugs.
Old Aug 15, 2009 | 01:12 PM
turbolove's Avatar
Member
Well my car was running bad shaking well pressing th gas and what not so i asked my mechanic and he said it was most likely the coil pack and or the plugs so i was like whatever ill just change both. Unsure if that was the problem..... It did fix it alittle but not fully I also did the fuel filter and cone filter swap. But lately it has gotten worse and the check engine light came on and stayed on for 2 days then turned off. The second it went on I went to Autozone and they told me 3 out of 4 cylinders were misfiring......... So I havent had a chance to go to the shop and have them take a look but its sucks.....
Old Aug 16, 2009 | 10:59 AM
wake0n's Avatar
It could be a bad MAF (Mass Air Flow Sensor).
Old Aug 16, 2009 | 11:36 AM
jojoenglish85's Avatar
i have the same problem also, but when i get my BT software this week, im going to have them change the coil paks, plugs, and clean my maf, i just got a new one this year to pass inspection.
Old Aug 17, 2009 | 10:58 AM
turbolove's Avatar
Member
My MAF is like a year old.. I cleaned it a couple of times. Didn't do much, i have no chip im basically stock.... DP, cone filter, Forge BOV/DV. When i changed the plugs i did the cone filter, coils, fuel filter, dogbone mount, cleaned the MAf, and the MAF plug looked bad so i got a new one and rewired it...
Old Aug 17, 2009 | 03:05 PM
ouTTie914's Avatar
Do you have a boost gauge? Your problem could be a vac leak. Considering it's just cylinders 2,3,4 check the hoses after/under the intake manifold.
Old Aug 17, 2009 | 04:54 PM
ilackav8's Avatar
i have a similar problem in my a4. last week i replaced the coil packs and plugs, and the cel is on again as of last night(misfire in cyl 3). its at the shop now and theyre tryinh to figure it out. ill let you know...maybe we have a similar issue.
