Misfire....
Well my car was running bad shaking well pressing th gas and what not so i asked my mechanic and he said it was most likely the coil pack and or the plugs so i was like whatever ill just change both. Unsure if that was the problem..... It did fix it alittle but not fully I also did the fuel filter and cone filter swap. But lately it has gotten worse and the check engine light came on and stayed on for 2 days then turned off. The second it went on I went to Autozone and they told me 3 out of 4 cylinders were misfiring......... So I havent had a chance to go to the shop and have them take a look but its sucks.....
My MAF is like a year old.. I cleaned it a couple of times. Didn't do much, i have no chip im basically stock.... DP, cone filter, Forge BOV/DV. When i changed the plugs i did the cone filter, coils, fuel filter, dogbone mount, cleaned the MAf, and the MAF plug looked bad so i got a new one and rewired it...
i have a similar problem in my a4. last week i replaced the coil packs and plugs, and the cel is on again as of last night(misfire in cyl 3). its at the shop now and theyre tryinh to figure it out. ill let you know...maybe we have a similar issue.
