Modschack Intake noise / moan *help*
Old Mar 1, 2008 | 08:47 PM
Oshuwah's Avatar
Default Modschack Intake noise / moan *help*
There is a noise (might be some sort of harmonic) when air flows under light boost (i.e. going up a steady hill with the car in cruise control). The sound would be best described as a moan, but it has pitch to it, like a harmonic tone. Sounds like a dying dog's last cry.Any thoughts on what this could be?
I bought the car from a vwvortex.com forum member who installed the kit himself. He did use a tube to suck in air from the front clip. He said the noise started when installed the kit.
It is really annoying!
Please advise...Josh
Old Mar 1, 2008 | 09:06 PM
Murderface's Avatar
Default RE: Modschack Intake noise / moan *help*
Just a side effect of having an intake basically. Nothing you can do about it other than get a different intake.
Old Mar 1, 2008 | 09:32 PM
jojoenglish85's Avatar
by mine i have had no problems if you want to call it that with mine. But with my bigger turbo all it does is restrictmy air flow now, but its fine for yours
Old Mar 2, 2008 | 12:03 AM
beachchair's Avatar
I still have my stock 1.8 Intake Box. It makes no noise at all. If your interested in some sort of trade PM me.
Old Mar 2, 2008 | 12:53 AM
tom1222's Avatar
ORIGINAL: Oshuwah
Whenever you open up the airbox you will get more noise. Louder whoosing from the DV or louder spooling noises from the Turbo. Most people actually find it
quite pleasant and not annoying. I never have heard it described as a moan before either. However, if you don't like the noise you will have to go with a closed intake system or go back to the stock airbox. It keeps the noise down to a bare minimum.
Old Mar 2, 2008 | 11:06 AM
scoTT la rock's Avatar
you should post about this in the audiworld.com tt section, the dude who makes them posts there all the time. maybe he can help?
Old Mar 2, 2008 | 02:31 PM
Oshuwah's Avatar
I emailed him (Steve) and he said it sounds like the stock diverter valve is going bad. Said it hill honk like a goose when it gets real bad. Luckily I have a Forge DV that the seller gave me with a car. I hope that's all it is. Now I have to find a good shop in southeastern PA to put it in.
Old Mar 2, 2008 | 03:27 PM
cincyTT's Avatar
I'm make believe
A dv takes a screwdriver and 2mins to install. A 2nd grader can do it.
Old Mar 2, 2008 | 03:51 PM
.clipse's Avatar
SoCal Crew Member
^ 2 mins. is exaggerating.
1 minute.
Old Mar 3, 2008 | 12:54 AM
themysteryman83's Avatar
oh god please don't take your dv to a shop to have them put it on...
