Modshack Stage 3
Old Apr 15, 2007 | 05:02 AM
moeron7's Avatar
Default RE: Modshack Stage 3
Ok well I turned my modshack stage 3 up to 4 turns and my car does not like it at all! When I step on it my DV sounds like its puking, it is very spitty and choppy. For a second, my CEL came on, but it only came on for a sec! Every time I step on it, It sputters! I dont know what the hell is goin on! Do I need to change out my DV spring or what!
Old Apr 15, 2007 | 06:11 AM
225tt's Avatar
Yes you do have to change it so that it will hold and release the boost better. I run the blue spring and it works like a charm.
Old Apr 15, 2007 | 01:50 PM
MeanAudiA6's Avatar
i run the yellow.....
Old Apr 15, 2007 | 01:58 PM
moeron7's Avatar
I have the yellow in now, I'll change to the blue and see how that works.
Old Apr 15, 2007 | 02:06 PM
MeanAudiA6's Avatar
it may be becuase of the giac x software its very agressive
Old Apr 15, 2007 | 07:13 PM
moeron7's Avatar
ORIGINAL: 225tt
Whats the highest PSI you hit before it goes back to a steady 20PSI?
Old Apr 16, 2007 | 09:13 AM
225tt's Avatar
The highest number that I have peaked at was 24psi but that was just a single instance, most of the time with the weather changing and everything I will peak around 22psi then level off at 20steady. Hope that helps.
PaTTy225
Oct 20, 2008 05:44 PM
DurTTy
Nov 9, 2007 03:19 PM
Bigrigatoni
Oct 22, 2007 01:36 PM
Bigrigatoni
Oct 21, 2007 12:48 PM
sacgns
Jul 17, 2006 10:08 PM
