More problems...quick Q
Old Jan 18, 2008 | 11:01 AM
projlightning's Avatar
Default More problems...quick Q
Well, after replacing the tensioner pulley and a busted belt, my power steering started to whine. I'm thinking when the belt busted, it knocked a hose loose or something(I haven't crawled under to check). I opened the resovoir to check the fluid level and to my amazement, I could see the bottom. This is my daily driver so I had no choice but to use some Prestone power steering fluid I had at home(last night). After searching the forums(today), I found out that I'm suppose to use a mineral based fluid(dealer item). Now, my quick question is, will I be fine with the fluid I used or should I drain it out and replace with the correct fluid?
Old Jan 18, 2008 | 12:18 PM
Default RE: More problems...quick Q
Did an online search on the fluid I used and it says "ALL VEHICLE EXCEPT HONDA"
Is that good or bad? I've heard that hondas and audi use the same stuff....[sm=WTFsgign.gif]
Old Jan 18, 2008 | 12:29 PM
diehlryan's Avatar
I would answer but I dont know anything about it.. sorry.
Old Jan 18, 2008 | 01:16 PM
TTT
Old Jan 19, 2008 | 10:37 AM
TTT
Smokin Tubes
Feb 5, 2012 10:11 AM
redrhino
Oct 26, 2011 03:49 PM
khj677turbo
Dec 23, 2007 06:00 PM
commedecargons
Nov 9, 2005 06:43 PM
SamJamaica
Jun 13, 2005 02:07 AM
