Is my DV leaking boost??!!
Old Feb 28, 2008 | 05:47 PM
jojoenglish85's Avatar
Default Is my DV leaking boost??!!
So ever since i replace the turbo in my car, when i step on the gas and going boost, my car seems to be hesitating.
Just now i took a buddy around the block after switching my modshack airintake for a shroom filter, and i was able to actualy hear my DV(turbo xs) seem to be sputtering as the boost increased. So im not sure if its holding the boost very well but that was my impression.
Besides that the car runs great, just doesn't hold up the boost is what its sounding like to me. WHat do you think?
Old Feb 28, 2008 | 06:05 PM
ouTTie914's Avatar
Default RE: Is my DV leaking boost??!!
Heh, yeah your Turbo XS has a HUGE leak... directly into the atmosphere!
I don't have any BOV experience, but is it adjustable?
If it's releasing while you're still on the gas, you'll need to stiffen it up so boost is held until you let go of the gas.
Why don't you have a boost gauge? That's the fastest way to tell if you have a boost leak.
Old Feb 28, 2008 | 06:12 PM
tom1222's Avatar
I would get rid of the BOV (turbo xs) and get yourself a good DV like the Forge 007P.
Much more reliable and they work a heck of a lot better than those PFFT valves [8D]
Also to smooth out hesitation off the line you can get yourself a MBC or a Boost Machine.
You can adjust the bleed off and the oncome of the boost and smooth things out quite a bit.
Old Feb 28, 2008 | 06:22 PM
Well i meant to say DV(turbo xs) But my gauge hasn't come in yet so i have to wait until next friday to purchase one
Old Feb 28, 2008 | 06:26 PM
ouTTie914's Avatar
You must have one of the Hybrid valves, again I don't know much about them.
Is it adjustable in anyway?
Old Feb 28, 2008 | 06:27 PM
themysteryman83's Avatar
Well, the TT wasn't designed for a bov and will cause problems unless specifially modified for one. Cincy knows how to do it, but it you just replace your stock dv with a bov that could be what's causing your problems.
Old Feb 28, 2008 | 06:37 PM
well im going to find out if its adjustable or not, cincy told me to go with a 004 by forge so i have one in the cart right now but i want to make sure this turbo xs DV can't be adjusted before i spend more money.
Old Feb 28, 2008 | 06:38 PM
ouTTie914's Avatar
A hybrid valve recirculates under low pressure, and releases to the atmosphere under high pressure. ...I think
So it does it's job just fine. Like I said if it's adjustable you'll want to stiffen up the recirculating part so it holds longer.
Old Feb 28, 2008 | 06:47 PM
ya its adjustable but i don't know how to tighten it, it doesn't come with washer or anything because it was on the car when i bought it...
im gonna go mess with it but if i can't get it to work then im buying a new that i know will work.
Old Feb 28, 2008 | 07:34 PM
ouTTie914's Avatar
Click
I'm sure you could pick up some washers at home depot or lowes.
It'd be cheaper than buying a new valve... Your decision though, good luck!
