Need help...cant get strut out!
Old Feb 2, 2009 | 06:27 PM
4mymalamute's Avatar
Default Need help...cant get strut out!
I am about to freak out on this car (ok, not really but its getting really old!). I am taking out the stock struts (and shocks in rear) and putting on some H&R race springs. The issue is this........for the life of me I can not get the strut out of the wheel bearing houseing. I am rigged up a tool that looks like the one in the Bentley book (tool 3424 spreader tool) but I cant get that damn thing to open the wheel bearing housing that is clamped around the strut. Does anyone have some tips for me on this? This is my third attempt and now my wife and neighbors think I just like taking off the tires and wrenching for the hell of it.........
Old Feb 2, 2009 | 07:23 PM
MCPaudiTT's Avatar
A quarter inch ratchet extension will do the job. Once you get frustrated that you can't collapse the spring enough, just drop the control arm.
Now is the perfect time to add DEFCONs, as well.
Old Feb 2, 2009 | 07:24 PM
achTTung's Avatar
That tool should do the trick, assuming you made it wide enough. I made mine out of a half inch bolt, sanded opposite sides until it just fit in the gap, and shaped the wider points with little flats so that once it was spread fully, it'd lock in place.
Here's the metalnerd version. I'll eventually make one like this when we get our machining center at work.
Mossyoakglock
May 5, 2014 02:03 PM
ptegowski
Feb 6, 2011 07:00 PM
MEOONG
Apr 6, 2007 04:35 PM
Sp33d07
Sep 3, 2006 01:40 PM
Kdog2112
Jan 16, 2006 06:09 PM
