2005 A4 Front Strut Replacement - Strut removal question
Old Apr 30, 2014 | 09:19 AM
Mossyoakglock's Avatar
Default 2005 A4 Front Strut Replacement - Strut removal question
I tried searching but could not find anything. It was all ads for Blauparts.
I am going to be replacing the struts/shocks on my wife's '05 A4 Non-sport suspension quattro this weekend.
The rear shocks look easy enough from the little I've researched. My question is on the front struts. I found a DIY one one of the other Audi sites that says if your car has a lot of miles on it that it might not be a good idea to try and remove the entire suspension assembly because the crimp bolt usually seizes around the upper ball joints. It says that you can remove the plugs that are in the engine bay and just remove the spring/strut assembly that way.
Is it doable that way? I'd like to avoid any unnecessary steps and not have to remove the entire upper control arm and just remove the strut.
Old May 5, 2014 | 02:03 PM
Bump to top.
Nobody has any input?
I looked under the hood and only found 1 body plug. Is there only 1 on the 2005 A4 with standard suspension?
I did the rears and it took maybe 30 minutes to do both sides.
I don't really want to have to mess with removing the pinch bolt and any else not needed.
jeckel20003
Jul 28, 2012 09:18 AM
danmackvail1
Jun 25, 2011 07:38 AM
ptegowski
Feb 6, 2011 07:00 PM
Smecker
Aug 16, 2008 08:10 PM
90sMoneypit
Dec 19, 2007 09:14 PM
