new gauges but...
Old Dec 26, 2007 | 11:41 PM
ilovemyTT's Avatar
Old Dec 26, 2007 | 11:47 PM
cincyTT's Avatar
I'm make believe
Default RE: new gauges but...
Well the a/f gauge is worthless since its for a narrowband. As for the boost gauge, tap into your dv vac line and you got boost/vac readings. Then just find a 12v source and a ground. THere is a grounding spot already in use that you can use just below the steering wheel. For the power source, you can just tap into the battery power to the fuse box in the kick panel.
Old Dec 27, 2007 | 01:06 AM
ilovemyTT's Avatar
oh. what other gauge would you recomend then?
and do you have a diagramof the engine so i can tap into the correct vac line. i dont know much bout audi's
Old Dec 27, 2007 | 01:07 AM
auditech79's Avatar
EGT (exhaust gas temperature) gauge.
Old Dec 27, 2007 | 01:10 AM
ilovemyTT's Avatar
oh ok. how would i hook that up?
Old Dec 27, 2007 | 01:15 AM
auditech79's Avatar
Good gauges usually have instructions, you have to drill and tap the exhaust manifold.
Old Dec 27, 2007 | 12:29 PM
redsapphire89's Avatar
off topic kinda but what pillar is that and can you take a better picture of the pillar so i can see how nicely it fits if not o well if you would be so kind thank you =)
Old Dec 27, 2007 | 11:50 PM
ilovemyTT's Avatar
actually it doesnt fit perfectly. i kind of made it fit. its just universal. eventually i'll get the toyota supra one.
monroegann
Oct 25, 2014 02:49 PM
warpedhalo
Jun 28, 2012 11:03 PM
aberfitch82
Oct 23, 2007 01:40 PM
huviduc
Aug 10, 2007 07:08 PM
Dj Spiel
Feb 8, 2006 10:58 AM
