New noise - help diagnose
2001 with 42,000 on it. Only happens on ice cold start up (overnight). It sounds like a pump kicks on for 30 seconds or so and it has a bad bearing in it. That's the only way I can think to describe it.
I had the dealer check it and they said "it's normal" and it has something to do with a the catalytic converters getting air diverted to help them heat up. huh?[sm=dontgetit.gif]
Any ideas?
Any ideas?
ORIGINAL: Kafn8td
Any ideas?
Any ideas?
ORIGINAL: rayveedub
i thought the air pump was electric? and you should deal with the sound until it dies, otherwise you have to shell out 200 bucks for a new one.
secondary air pump is electric not belt driven and they do get noisy when weather is very cold basically its doing its job but can be annoying, if you think the noise is excessive then a new pump might be required
ORIGINAL: rayveedub
i dont think you can replace the bearing in it, i definatly looks like a r and r part.
My car did the same thing last night!
Scared the hell out of me, I can't cope with the idea of something being wrong with my TT. [:-]
Okay so I'll ask again.
What other strange noises or system lights can be expected from cold weather?
nottiaudi
B7 Models
May 9, 2012 03:02 PM
