new TT owner...2 problems, and need help
Old Oct 31, 2007 | 11:38 PM
Stunter4Hire's Avatar
Default new TT owner...2 problems, and need help
Just bought a 2003 audi tt 1.8t quattro, everything is great on the car except for two things
1. my fuel guage is deffinitly off. It read 3/4 a tank today but it took $35 to fill it up?????whats up with that????
2. The power steering makes a little sound when im turning right at high speed (40mph or above). But not when im going straigh or turning left. Also since its all wheel drive i know it will be hard to turn at very slow speeds, but mine seems excessivly hard??? I checked the fluid level and it is good!
can anyone give me a hint as to what is causing these problems? Or how to fix them?
Old Oct 31, 2007 | 11:59 PM
XCLR8TT's Avatar
Default RE: new TT owner...2 problems, and need help
1) Run a couple of tanks with Techron added. The problem you describe can often be due to sulphur compound deposits on the fuel sensor. Short of that it may be a problem with your cluster or replace the tank sensor.
2) Might be bad strut bearings or the power steering pump. Take it into a reputable aligmnet shop and have them diagnose for you. Find someone who has a Hunter 4 wheel alignment system, they should have the tools and the know how to determine what the problem is.
Old Nov 1, 2007 | 08:27 AM
alan93's Avatar
1. The fuel sender in tank is the problem most often from what I found. Mine went bad.
Doesn't hurt to try cheaper or more convenient fixes first .
2. What type of sound. I had a similar situation on mine. Is it a pop or knock sound?
Any warranty left?
Old Nov 1, 2007 | 11:09 PM
how much is a new fuel sensor? and how hard to replace? im a half decent mechanic, but i dont know **** about these cars yet so bare with me.
also its not a knock or anything like that. Its just a slight moan when i bare to the right. Also i noticed today that when turning slow its hard to turn, but if i rev up the motor it makes it 10 times easier?
Old Nov 2, 2007 | 11:20 AM
alan93's Avatar
Got one of these yet?
Service Manual
Would recommend it
Hawley12
Dec 15, 2013 05:49 PM
rinupanu
Mar 10, 2011 01:43 PM
Wahooz
Jun 14, 2008 12:14 PM
nbwaverydr83
Feb 1, 2007 05:55 PM
Mosie84
Sep 21, 2006 02:19 AM
