No 1st or 2nd gear?
I just got my car out of the garage after 8months of procrastinating with maintenance and custom work. I was on my way to the bank for a cruise and everything was smooth, i get into the parking lot and i go to put it back in first. Nothing 1st and 2nd gear wouldn't catch. They into place, but no clicking into place feeling just loose. 3rd-6th work and reverse. I took out my airbox and looked at the linkage. Everything looks alright...Any suggestions on what to do next? or what it could be?
I am having a problem with my shifter right now too. Mine is stuck in the 1st gear position though and I cant even drive it. I wonder if it is a similar malfunction to yours? If I get any advice I will let you know...
Good luck!!!
Ben
Good luck!!!
Ben
Your 1/2 shift fork flange which catches with the shift rod in the transmission has fallen off. Sounds like it didn't hit any other gear, which is good!
O2M 6spd- alloy shift forks? discuss.. [Archive] - eurowerks.org
VW 02M Transmission Shift Fork Issues | Blue Water Performance
VWVortex.com - O2M-Anyone successfully strengthened shift forks?
This LITERALLY just happened to me (I got '01 TT Quattro) and I am freaking pissed with Audi for using such a cheap *** rivet to hold this **** in place. Cost me 1.5K to open it up, replace the fork with a stronger bolt, and put it all back together. I want to sue audi so bad. Good luck!
Oh, bpdeleon, same thing most likely happened to you except the flange/broken rivet that falled off got stuck in the gears....Don't start that **** up and try to move, keep it in neutral the whole time. Hopefully there isn't too much damage to the gears...
My linkage was dry rotted and I was stuck in 4th gear just this past weekend.
In the shop as we speak. 118,000 miles and 10yrs old
Yes! pretty shitty linkage. You would think it would last a lifetime.
Wonder if AOA can do anything?
qcapson
Jan 14, 2007 12:15 AM
merlin12volt
Dec 14, 2006 05:51 PM
