No start after new coils install.
Old Mar 1, 2015 | 08:44 PM
Luis401's Avatar
Default No start after new coils install.
After tune up (coils and spark plugs) my car 2001 Audi TT quattro 180hp will not start. After so many cranks my Battery started to drain. I tried jumping to my Nissan 2014 Murano and still car will not start. Tried removing radio fuse due to aftermarket Alpine radio (which has been working perfect before attempting tuneup) and nothing. Also tried removing the ABS fuse and all my car does is try to start as if there is no gas (Tank almost full). I should mention when ignition is turned I cannot hear the gas pump priming. Car has been running and starting perfect before attempting tuneup! WTF..now I can't read fault codes because scanner can't read from odb port which displays "No Link" error! Please help. Also noticed my CEL does does not come on, found fuse #10 is blown which has something to do with info from coils and fuel pressure (read that in another post) so I will replace fuse, then I will put the OEM coils back on (ebay "performance coils" were installed may have too strong of a signal ) therefore blown fuse, cross my fingers! Hopefully I can get a reading from the obd port.
Old Mar 3, 2015 | 11:44 AM
Luis401's Avatar
Default No start after new coils install "FIXED"!
The problem was the so called "performance" coils purchased off eBay. Apparently the coils electrical signal to the ECM was too strong causing fuse #10 to keep blowing upon start. Replaced the OEM coils left the new Bosch plugs in, replaced fuse #10, turned ignition and BANG! Started up first shot! Hope this helps others having similar issues.
Old Jun 22, 2015 | 04:49 PM
ppgoal's Avatar
Good lesson on non-oem coils. Thanks for sharing and glad you found the problem.
rory2523
Nov 14, 2010 08:58 PM
silveraudi98
Oct 20, 2008 07:29 PM
allroad2.7t
May 27, 2008 03:26 PM
topj
Mar 30, 2008 12:43 PM
mypreludeisred
Mar 31, 2007 02:35 AM
