oil catch can
Old 02-04-2007, 04:53 PM
MeanAudiA6's Avatar
Default oil catch can
is this what people are using for the homemade oil catch cans? CincyTT? lol you have to put this in the search field 100027474
http://www.homedepot.com/prel80/HDUS...0&MID=9876
Old 02-04-2007, 06:08 PM
cincyTT's Avatar
I'm make believe
Default RE: oil catch can
that is the exact one on my car. all you need is a few $ in fittings and hose.
Old 02-04-2007, 06:13 PM
hmmm site has nothing to do with oil change more for a sales advert if you ask me
Old 02-04-2007, 06:22 PM
MeanAudiA6's Avatar
sweet! i'm trying to find the fittings on that site but no luck guess when i go in there to buy it i'll just open the package and go around pluging stuff in to it till it fits. lol did you use just some heater hose from like NAPA? i might actually have some left over silicon that might work.
So all you have to do is cut that formed hose coming from the block and the hose steming from the turbo boost pressure regulator(black flat circle top piece) and put the catch can in between them?
Old 02-04-2007, 06:33 PM
I use an old oil can and cut the side off ( plastic of course ) 5 litre in and 5 ltrs out or what ever quarts you use ( all it is is a catch bin )
Old 02-04-2007, 06:48 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: MeanAudiA6
The top of the package you can easily take off and there is a large amount of fittings buy the filter but cheaper done the isle with some plumbing items.
heater hose will work fine.
Old 02-04-2007, 06:53 PM
homemade oil catch cans? now its converted to coolant change what are you doing??
Old 02-04-2007, 07:01 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: avant80@2.6
im totally lost in this post. if you have any ?'s of want to see pics scroll down to my thread titled about the same.
here https://www.audiforums.com/m_443365/tm.htm
Old 02-04-2007, 07:02 PM
DenimTT's Avatar
Avant, Its to filter oil out of the crankcase breather from entering the intake and turbo. Nothing to do with oil changes or coolant.
Old 02-04-2007, 07:12 PM
oh hell what a dip im not used to this but I understand what your talking about so ill read up on it ( watch out though im quick on the uptake ) im sure he mentioned an oil change though.
Quick Reply: oil catch can
