oil drain plug ?
Old Jul 24, 2008 | 08:41 PM
TT4fun's Avatar
Default oil drain plug ?
So this might be a stupid question but is the oil pan drain plug not reuseable?
The bentley manual says "Oil drain plug is equipped with a permenant seal. As a result, drain plug must always be replaced."
Thanks.
Old Jul 24, 2008 | 08:52 PM
GHETTOxWHITExBOY's Avatar
Default RE: oil drain plug ?
ITS A SPECIAL PLUG !!! BUT I DO BELIEVE ITS REUSABLE
joshuo's Avatar
No, there is a replacement seal with the oil filter.
Old Jul 24, 2008 | 10:30 PM
TT4fun's Avatar
What is the part number of the oil filter that comes with it?
Old Jul 25, 2008 | 04:42 AM
beachchair's Avatar
ORIGINAL: TT4fun
Thanks.
Bentley is very specific and mentions in a couple of places to always replace the plug due to the permanent seal. I just buy several at a time, and always change mine. They aren't expensive, and it's not worth chancing a leak.
Old Jul 25, 2008 | 04:32 PM
kwaskow's Avatar
I did my first oil change about two weeks ago and reused hte drain plug with no problem and no leak
Old Jul 25, 2008 | 04:36 PM
cincyTT's Avatar
I'm make believe
I reuse mine all the time. I did however switch to a cheap magnetic plug from autozone ($5 M14)which was good since it cought my oil squirter after my engine build which help save the engine from more damage. And its the washer you are suppose to replace when you change the oil, they can be bought for cheap from the dealer or ecstuning
Old Jul 26, 2008 | 01:38 PM
DeepBlueT's Avatar
my drain plug from ECS tuning came with like 15 copper crush washers!
Old Jul 26, 2008 | 04:36 PM
beachchair's Avatar
ORIGINAL: kwaskow
Your free to do whatever you want. It does seem excessive to replace it each time. You'll most likely get away with it, but there's always the chance of failure from a very inexpensive part. The issue is the Audi plugs come with a "permanant seal" as opposed to a replaceable washer.
Old Jul 26, 2008 | 05:56 PM
TT4fun's Avatar
So you can get a bunch of them from the dealer pretty cheap?
