possible damage;oil buildup in cracked intercooler;smoking
Old Jul 21, 2011 | 12:35 PM
audiaubrey's Avatar
Default possible damage;oil buildup in cracked intercooler;smoking
any suggestions on what else i need to inspect for damage done to my car.. boost completely went out, cracked intercooler, oil buildup on the inlet side of the intercooler..
just want to know what else i should look for while im replacing parts...hoping i dont need any engine/turbo work...
thanks
Old Jul 22, 2011 | 12:17 PM
cincyTT's Avatar
I'm make believe
The oil is coming from the pcv system in the car. The hoses that run from the block and head to the intake. It was oil vapor and when it cools, it turns back to oil and pools in the intercooler. Its normal. If you cracked the intercooler (sounds hard to do) then it has to be replaced since you can make pressure with a big hole in the system and your car will be fine.
Old Jul 29, 2011 | 06:59 AM
JEDGE1.8T's Avatar
do you have the 180hp or 225hp, cuz the 225s are twin intercooled, both in front of each tire
Old Jul 30, 2011 | 05:54 AM
audiaubrey's Avatar
1.8t. got new parts in yesterday..going to put in the new intercooler and hope it works!! then switch out all my piping to aluminum...and then hope that there was no damage done to my turbo!!
im stokeddddd to get this on the way!
audiaubrey
Jul 22, 2011 12:22 PM
A1EK
Oct 5, 2009 09:53 AM
fourGbeast27t
Sep 29, 2007 10:11 AM
NoVA_AudiA6
Apr 10, 2007 08:01 PM
