Power Steering Making Whining Sound
Old Feb 14, 2012 | 10:48 AM
edder b's Avatar
Default Power Steering Making Whining Sound
I have a '05 3.2 TT Roadster that I just bought back in December. Love the car. I have noticed that the power steering unit whines now and then, mostly when its cold. Is this normal? Where can I check the power steering fluid?
Old Feb 14, 2012 | 01:07 PM
cincyTT's Avatar
I'm make believe
Not sure if the 3.2 is located on he same location as a 1.8 but it should be a green cap with a steering wheel on it. There is a dip stick on the underside of the cap. Make sure the fluid isn't dirty while you are in there also.
Old Feb 15, 2012 | 07:38 PM
IronCobra53's Avatar
mine whined for a while mainly when it was cold, i checked my fluid n i was low, i added some n it never returned n tht was about 5k ago, i check it periodically though, just make sure u use the vw steering fluid ( its green ) ecstuning.com has it for a reasonable price
Old Feb 16, 2012 | 03:05 PM
edder b's Avatar
Thanks for the responses. The power steering fluid on the 3.2 is located under the black plastic panel in front of the radiator reservoir. The local dealer was kind enough to show me where it is. Checked OK, guess I'm just a little paranoid of noises.
Old Feb 16, 2012 | 03:42 PM
cincyTT's Avatar
I'm make believe
My a4 has the same issue. There is a one way valve the keeps pressure to the the pump. Mine needs replacing and should fix my problem. There is one on the TT also. Join vagcat.com and go to this link, number 14 might be what you need if it continues.
Audi TT Coupe/Roadster 2005
pwonder
May 3, 2009 01:45 PM
paaudia6
Jan 3, 2008 08:08 AM
mustang196718
Mar 20, 2007 02:05 AM
satishtadi
Oct 29, 2006 11:25 PM
apg96
Apr 19, 2005 11:23 PM
