problem is just getting old.....
ya had to rename the video today... turns out both MAF sensors i had were junk stupid ebay ones. Put stock back in runs awesome.
Check all Vac hoses in and out of the N75. Change out the N75 Are you using a MBC?
Mine does the same and when it happens too me I pull over shut it off and its fine.
Vac leak if you cannot find it change all vac lines and run Maf less.
I ran Maf less for quite sometime por gas mileage and then I bought a new Maf!
Good Luck!
Good Luck!
Good Luck!
Good Luck!
even when i had a MBC i couldnt even go over stock boost without it happening. turbo was junk too.
