problem is just getting old.....
Old Dec 24, 2011 | 07:48 PM
ziggyTT's Avatar
Default problem is just getting old.....
Audi TT problems - YouTube
sputters at 5 psi.
cel system too rich p1127
Old Dec 26, 2011 | 12:35 AM
audi08bry's Avatar
Have you tried cleaning the MAF sensor? You can use CRC MAF cleaner or some rubbing alcohol to clean them. Just make sure the MAF is fully dry when you put it back in. That might help.
Old Dec 26, 2011 | 06:15 PM
ziggyTT's Avatar
ya had to rename the video today... turns out both MAF sensors i had were junk stupid ebay ones. Put stock back in runs awesome.
Old Dec 27, 2011 | 11:21 AM
coachvtt's Avatar
Check all Vac hoses in and out of the N75. Change out the N75 Are you using a MBC?
Mine does the same and when it happens too me I pull over shut it off and its fine.
Vac leak if you cannot find it change all vac lines and run Maf less.
I ran Maf less for quite sometime por gas mileage and then I bought a new Maf!
Good Luck!
Old Dec 27, 2011 | 12:28 PM
ziggyTT's Avatar
Good Luck!
turns out just a junk ebay MAF. through stock one in and now it runs fine.
even when i had a MBC i couldnt even go over stock boost without it happening. turbo was junk too.
Old Jan 12, 2012 | 09:44 PM
rodhotter's Avatar
i use 99% alcohol, pour in plastic bag slush around let maf air dry, for a little more flow i remove the screen and plastic grid
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
