Recommended extended warranty companies?
Old Jun 12, 2007 | 12:13 PM
homer_ga's Avatar
Default Recommended extended warranty companies?
As the certified pre-owned warranty on my '01is running out later this month, can anybody recommend a good 3rd partyextended warranty company that covers the car like the Audi warranty? Will they place a car on an extended warranty that is six years old but only 46k miles? Any advice is appreciated.
Thanks,
Jeff
Old Jun 12, 2007 | 03:35 PM
cincyTT's Avatar
I'm make believe
Default RE: Recommended extended warranty companies?
i would go with the savings account and preventitve maintence. Change your timing belt around 60k and do regular oil changes (full syn)/spark plugs and you should be good. I have just over 100k on mine and the only thing that i need is a new ac compressor.
Old Jun 12, 2007 | 04:04 PM
bmwtoaudi's Avatar
I on the other hand have literally had to replace everything.
clutch/starter/water pump/timing belt/front left caliper/alternator/plugs....etc etc etc.
When ever I fix something, something goes wrong. - DOH!
Old Jun 12, 2007 | 04:10 PM
cincyTT's Avatar
I'm make believe
most of the things listed are wear and tear items. The only things that MAY get covered under a warrenty is athe caliper and the alternator. The rest you are SOL on.
Tweev
May 21, 2010 11:49 AM
mani
Dec 29, 2009 05:07 PM
munkee
Mar 16, 2007 09:29 AM
ou2mame
Dec 27, 2006 07:39 PM
coletrain
May 12, 2005 12:46 AM
