transmission oil and rear differential?
do they use the same oil? im planning to change my manual transmission oil with redline mt-90 and im not sure if it will use same oil on the rear diff.? can redline be purchased at local autoparts store? and do you use 3 quarts for the transmission and 1 qt on rear?
RE: transmission oil and rear differential?
2.1 quarts for the tranny on the 5 speed, 2.7 quarts on the 6 speed, and 1.1 quarts for the rear diff.
I have MT-90 for the tranny, and redline 75W90 for the rear diff. I cant remember my thinking on why i got the two types, they're the same weight I believe.
so was i correct in my choice of fluids?
Actually knowing that, wouldn't the 75W90 be a better choice in the transmission too, considering it shares fluid with the bevel box?
It is best to follow Audi's recommendation (I don't own a TT (quite yet)) so I can't say for sure. A hypoid gear set is slightly different from a bevel or spiral bevel gear set due to the offset of the shafts.
In general, more additive than what is necessary is not a good thing as it may havenegative effects on other properties of the oil.
Transmission - Gear oil: SAE 75 W 90 (synthetic oil) Part number: G 005 000 (same fluid for both 5 and 6 spd. only quantity changes)
Rear final drive - Gear oil SAE 75W-90 (synthetic oil)
Part number: G 052 145 A
Still gotta find the specs on those part numbers.
speedys4
03-13-2008 10:58 PM
mustang196718
05-01-2007 02:48 PM
052, 145, 2005, audi, bevel, box, diff, differential, differntia, fluid, gear, oil, rear, transmission, tt
