repair question any help ??
Old Nov 26, 2008 | 09:59 PM
branstone's Avatar
Default repair question any help ??
so our check engine light came on, t4051 fault i think it was they said
audihouse says it is secondary air system fault and it is probably the secondary air pump
so ok if this is whats wrong, they say "we always replace the kombivalve (??) when doing this work"
thoughts ?
Old Nov 26, 2008 | 10:44 PM
achTTung's Avatar
the combivalve is the shiny metal cylinder thing to the right of the valve cover. its on a steel tube that attaches to the side of the block. Theres also a vacuum line that goes to it, and an approx. 1" black corrugated hose. This is the point where the air from the secondary air pump meets exhaust (roughly).
btw, it'd be a P code (powertrain)....
http://www.bentleypublishers.com/tec....dtc.table.htm
take a look thru there, what you said (4051) doesn't exist.
kbunting
Apr 2, 2015 12:55 PM
Nevalite
Oct 21, 2010 08:28 PM
meh
Oct 20, 2008 09:46 AM
bsharp8
May 11, 2008 08:06 PM
Darknight101
Jul 5, 2007 03:08 PM
