On the Road Again!
Old Feb 1, 2007 | 06:46 AM
  #21
DenimTT's Avatar
Default RE: On the Road Again!
No boost machine. I was thinking a $30 MBC and the other N75, if necessary. If I can make it happen with just $30, then thats even better.
Old Feb 1, 2007 | 01:45 PM
  #22
cincyTT's Avatar
I'm make believe
get a bleed valve mbc and use it to replace the n75, you can leave it inline but it easier to just take it out. I have a turboxs hp mbc, it has both ball and spring and a bleed valve on it and the stock turbo spools to fast to use the ball and spring and makes it kinda jumpy. The ball and spring will be better for a bigger turbo that spools after 3k rpms and help spool it faster. The bleed valve will give you a better transition into boost than the ball and spring. Voodoo on ebay makes a copy of the turboxs one i have for about $30-40 would be a nice investment.
Old Feb 1, 2007 | 01:46 PM
  #23
cincyTT's Avatar
I'm make believe
ORIGINAL: FXRocket
wait wait ...so I can get more performance WITHOUT spending the $500 on a chip? I need more info....
send me a pm and i can help you, if you can solder its not that hard.
Old Feb 1, 2007 | 11:48 PM
  #24
DenimTT's Avatar
On a 180TTyou can get 6-7 PSI without soldering.
Old Feb 2, 2007 | 12:46 AM
  #25
cincyTT's Avatar
I'm make believe
.8 bar = 11psi. adding 6-7 psi = limp without a diode and a diode = soldering unless you plan on twisting it on the wires and that just scares me.
jasonball
Apr 23, 2025 12:20 AM
Audi_Skydiver
Mar 27, 2009 01:01 AM
maxframes
Feb 25, 2008 02:59 PM
tarrasque
Jan 29, 2007 08:18 PM
cuprabaz
Sep 20, 2005 01:44 PM
