Running rich
Old Sep 10, 2007 | 12:19 PM
ooantipostoo's Avatar
Default Running rich
Ok I have a strange issue here. On accelerated warm ups mostly my car will back fire but with no flames. Im also throwing a code P1136 i think it was for being lean. Im confused here thought you only backfire when your running rich. Also it seems like my intake is sucking alot harder than normal like almost a loud huffing noise and right now i have the check engine light reset. But when its running in open loop the car seems to perform better. I know opon loop is basicly giving you the same all around gas all the time as flooring it.
Old Sep 10, 2007 | 12:37 PM
cincyTT's Avatar
I'm make believe
Default RE: Running rich
If you dont have a cat, you can backfire easily. ALso on cold starts, the car dumps much more gas in, thats why you have a secondary air pump to recirculate the air and keep it environmentally friendly
Old Sep 10, 2007 | 12:39 PM
moeron7's Avatar
ORIGINAL: cincyTT
So thats what that thing is for.... I never knew.
F*** emissions.... Im looking to get rid of all this crap and just use what i need to make this engine run. There is no suck thing as a everyday driver and a moded fast car. And i want the 2 choice. But anywho I do have a cat so im still confused.
Old Sep 10, 2007 | 12:43 PM
cincyTT's Avatar
I'm make believe
Then you still have more gas than it can burn. But if you remove those items you will no longer pass emissions, so if you live in a state with testing, your stuck.
Old Sep 10, 2007 | 12:48 PM
I do but my mech friend is a smog tech so i will just need to find another 180TT in the area and im good to go. Or even a car around the same weight.
Old Sep 10, 2007 | 12:54 PM
cincyTT's Avatar
I'm make believe
You do realize that is Federal prison time and a huge fine right?
Old Sep 10, 2007 | 01:18 PM
Ya but there really isnt a way of getting caught. If pulled over and they find that you are not within emissions i can just say i modded afterwards get a fix it ticket and redo the whole smog and you dont have to visually show them just your new smog papers.
Old Sep 10, 2007 | 01:19 PM
Plus if you spend over i like 4 or 5 grand on "emission related repairs" and it still doesnt pass then you just let you have your registration.
discontained
Jun 10, 2007 11:12 PM
98a4T
Mar 25, 2007 07:38 PM
keko2004
Jan 12, 2007 04:53 PM
johnstef
Dec 24, 2006 11:29 AM
SuperS4
Jul 18, 2006 12:34 AM
