sachs clutch
Old Jul 13, 2008 | 06:20 PM
myslow1's Avatar
Default sachs clutch
ok well i knew it was going to happen. My engagement is getting worse. Anyone running a sachs clutch? its an oem replacement, i assume if broken in correctly it will hold power on a 225q with a chip, dp, and a couple other small things?
Old Jul 14, 2008 | 12:26 AM
cincyTT's Avatar
I'm make believe
Default RE: sachs clutch
Sachs is usually the most reliable clutch around. You will have no problem holding that with a stock replacement. However, if you are planning going bigger ever, best do it now.
Old Jul 14, 2008 | 12:38 AM
myslow1's Avatar
well for time being that is all i want... unless my car is already chipped i dont think i will want much more lol. I love the power it has right now. Plus my oem clutch is going out. I dont know if it is the pressure plate or the TOB but you can hear the clutch whine...
should i replace the flywheel too you think?
willie7182
Jan 14, 2012 11:31 AM
tyleryours
Jun 2, 2007 06:16 PM
willie7182
May 11, 2007 08:40 PM
GraffixWB
May 1, 2006 08:50 PM
