Seafoam
Old Oct 10, 2014 | 02:37 AM
kaikohe808's Avatar
Default Seafoam
I was wondering if it would be safe to use seafoam on a 2001 MK I to clean out build up in the block and also use it on the fuel system too
Thanks in advance
Stan
Old Oct 10, 2014 | 11:54 PM
bradtyler02's Avatar
A can in a full gas tank, half a can in the crank case, half a can through a vacuum line on the intake (you can google how to do that), then change the oil when its time to fill the gas again.
Old Oct 12, 2014 | 12:39 PM
mikaere808's Avatar
Default Rear brake piston
So i was changing my rotors and pads on my TT today and I can't seem to get the piston to retract so I can put the new rotor and pads on any ideas
Old Oct 12, 2014 | 07:32 PM
Rear calipers need to be screwed in while being compressed. Also, make sure you open the brake fluid reservoir when you're doing it. The right tool can be rented at almost any big box car parts store.
Old Oct 13, 2014 | 10:15 AM
mikaere808's Avatar
I did rent the tool and the problem is I need to get the piston retracted enough to get the tool in between the tool and the other side of the caliper.
Old Oct 13, 2014 | 02:53 PM
wow... did you step on the breaks after you took the calipers off or something? I don't think I've ever seen them that extended before. Not sure what to tell you, other than, good luck.
Old Oct 13, 2014 | 03:43 PM
mikaere808's Avatar
Default I know... dont know what to do
hows the cove.....I was stationed in Ft Hood for 3 years lol..... thanks for your help
Old Oct 14, 2014 | 04:08 PM
I hate this place and can't wait to PCS.
Old Oct 14, 2014 | 08:54 PM
kaikohe808's Avatar
Default What's your MOS?
At least you live in cove I lived on post in barracks
Old Oct 16, 2014 | 07:37 AM
Yeah, that would definitely be shitty
bshouler
Jul 7, 2010 09:11 AM
badlandz
Mar 21, 2009 12:17 AM
JohnnyS4
Apr 5, 2008 11:06 PM
Shwabmyknob
Mar 3, 2008 11:46 PM
vintravaia
Mar 3, 2008 12:38 PM
