The Shroom Filter!
Old Feb 26, 2008 | 11:46 AM
  #121
Skipponator's Avatar
Default RE: PICS of the SHROOM Filter Installed
ORIGINAL: doadea
Here are some pics of my freshly installed HKS Super Mega Flow Intake SHROOM! I still need to get a smallerfilterfor the other line, so I have not driven it yet.
What do you mean "other line"? Another filter for where? Before I order, I want to make sure I have everything! Thanks!
Old Feb 26, 2008 | 11:57 AM
  #122
cincyTT's Avatar
I'm make believe
The SAI takes in air from the air box. It needs a separate filter for it. Atp sells the filter for it.
Old Feb 26, 2008 | 12:50 PM
  #123
doadea's Avatar
ORIGINAL: cincyTT
Yeah I have not taken a picture of mine yet, but I made my own filter with a very high quality dense foam block that I had. I used a seraded knife and cut it to proportions and black twisty tied it. It is grey foam and matches perfectly with the engine.
Old Feb 26, 2008 | 05:24 PM
  #124
Senater_Cache's Avatar
will these filters work with an APR MAF? with Flow a Straightener?
just wondering because I am looking into a new filter (current = K&N drop-in in stock airbox...stock airbox basically has no bottom or sides left after I cut the thing lol :-) ) lol :-) )
thanks
Old Feb 26, 2008 | 08:57 PM
  #125
.clipse's Avatar
SoCal Crew Member
^ it should. if the MAF is wider, just get the filter inlet diameter the same size.
Old Feb 27, 2008 | 11:20 AM
  #126
cincyTT's Avatar
I'm make believe
The apr maf is still made to work with the stock airbox. So it will be the same
Old Feb 27, 2008 | 10:15 PM
  #127
Agnt008's Avatar
I'm still confused about some sort of breather filter we need? Where does this go and why? (Pics???) The pictures of the guy with the dual air filters has foil covering the intake hole on the very right side of his car where the old air box used to connect or something... anyone know why he would have foil over it?
Old Feb 27, 2008 | 10:24 PM
  #128
theTTkid's Avatar
the smaller filter goes over the secondary air hose which is the other hose attached to your stock airbox...
basically your MAF connects to the box and then right below it is another hose... thats the one the small filter goes on
Old Feb 27, 2008 | 10:29 PM
  #129
cincyTT's Avatar
I'm make believe
ORIGINAL: Agnt008
A4 Jed
Jun 23, 2013 06:13 PM
Niclipse
Feb 9, 2009 01:39 AM
RJizzle
Jun 14, 2008 01:21 PM
.clipse
Feb 25, 2008 03:20 PM
