silicon vac lines?
Old Dec 19, 2007 | 08:39 AM
joshuo's Avatar
Default silicon vac lines?
I want to replace all my vac lines with silicon ones.
does anyone know an approximate about how many feet of which thicknesses I need?
I remember there being a thread with a 225 with all red vac lines with measurements for each one,
but I can't seem to find it anymore.
also, does it really matter where I get them, i mean, its just silicon tubing right?
I was looking at hose techniques
http://www.hosetechniques.com/produc...ex&cPath=22_66
The install should be straightforward, right
can I reuse the stock little clamps?
thanks1
Old Dec 19, 2007 | 09:21 AM
multipass71's Avatar
Old Dec 19, 2007 | 09:28 AM
Default RE: silicon vac lines?
Sorry, you have to click on the picture and you will see the sizes.
Old Dec 19, 2007 | 09:47 AM
joshuo's Avatar
wow, thanks alot, that's the one!
so i need 8mm, 6mm and 3.5mm
does anyone know approximate lenghts? i can't guesstimete really well from that pic.
Old Dec 19, 2007 | 10:44 AM
I ordered a kit over the internet and it came with;
15 feet of the 3.5mm,
6 feet of the 6mm,
6 feet of the 8mm.
I haven't fitted it all but there seems to more than enough. And if you take a closer look on that engine, they are using zip ties instead of clamps on some of them. Sorry I can't remember what the name of the company that I got the kit from, but if you do a search you will find some.
Old Dec 19, 2007 | 01:28 PM
joshuo's Avatar
sweet, i found a kit on hosetechniques.
the only concern i have is how much vacuum the 225 1.8 can generate. the hoses i found are 25 In Hg proof.
my car idles at ~19-20 is that too close or am i just crazy?
Old Dec 19, 2007 | 01:46 PM
moeron7's Avatar
should be fine.
fourringking
Dec 23, 2012 03:26 PM
RenoRains
May 11, 2012 12:18 AM
RenoRains
Feb 5, 2012 11:14 AM
modaddy
Oct 4, 2008 01:50 AM
chaos92287
Jan 10, 2008 10:33 PM
