SO.. Where you guys mounting your water/meth pump?
Subscribe
Apr 1, 2008 | 09:38 PM
While the car is down waiting for parts, im also going to do my snow oerformance water meth kit ( dual nozzel) where is everyone mounting their pumps?thanks Wayne
Reply
Apr 1, 2008 | 09:40 PM
RE: SO.. Where you guys mounting your water/meth pump?
do you allready have the kit? devils own is way better get in the group buy while you still can return the snow if you have too.
Reply
Apr 1, 2008 | 09:54 PM
i have had it for 5 months sitting on a shelf, at the time everybody said the snow was better than devils, who knows i'm sure it will be fine.
Reply
Apr 1, 2008 | 10:01 PM
I'll probably run a lightweight battery/relocate the battery, and put the pump/tank in that vicinity.
Reply
Apr 1, 2008 | 10:25 PM
Quote:
ORIGINAL: achTTung
I had the same thoughts. You can also mount it in the trunk like a few others have. Then you can run a much larger tank with it.
Reply
Apr 1, 2008 | 10:32 PM
i am mounting it where the sai pump used to be
Reply
Apr 1, 2008 | 11:04 PM
I thought about the trunk , is this thing going to be loud? I also thoutght about drilling out a NOS tank and using it for the water/meth solution ,, is that gay?
Reply
Apr 1, 2008 | 11:12 PM
I think its a little costly and kind of tacky. If you put the tank in the wheel well with the cover over it, you shouldnt hear it
Reply
Apr 2, 2008 | 05:40 PM
Also considered mirroring the windshield washer tank, on the passenger side. I can build a tank to fit, problem is making sure its not out of something methanol will attack (aluminum and meth don't get along if you're storing meth in an aluminum container). Thought of maybe coating the inside of the tank with an epoxy. There are a few out there designed with methanol containment in mind.
Reply
Apr 2, 2008 | 07:30 PM
well since i have a lot more room in the engine bay now(thanks SAI and EGR delete) idk yet...maybe where the SAI pump was or maybe near the intake....ya prolly near there somewhere under the boost machine.
Reply
Subscribe
