software or chip?
Old Jul 18, 2007 | 04:25 PM
zero388's Avatar
Default software or chip?
A while ago I got APR's software downloaded to my ecu. I was contimplating getting a chip but decided on the software because I didnt have to take out my ecu or anything like that. What I want to know is if there are any advantages to getting an actual chip or if the software is just the same?
thanks guys
Old Jul 18, 2007 | 04:30 PM
Vorais's Avatar
Default RE: software or chip?
Software is the same. However, if you want multiple programs you will most likely need a chip as mos tof the ecu's can only hold 1 program at a time without the add on.
Old Jul 18, 2007 | 05:37 PM
AudiOso's Avatar
That's not true. APR flashed my chip with stock, 93, 100 and valet mode as well as throttle body adjustment and fault code erase.
Old Jul 18, 2007 | 06:51 PM
cincyTT's Avatar
I'm make believe
Us ATC people have tiny ecu's. you most likey need a chip soldered since space is severally limited. Flashes are easier to remove/changed than a chip, expecially since some dont so it so cleanly.
Old Jul 19, 2007 | 12:53 AM
225tt's Avatar
GIAC flashed three programs onto my ECU as well...never had to take it out.
Old Jul 19, 2007 | 12:05 PM
Vorais's Avatar
ORIGINAL: Vorais
Sorry guys, I didn't bold the most. Some of the ECU's, especially the newer ones can flash several programs. However, many of the chips can only hold 1 program. Before I started going BT, I had my car chipped to 91 and 100 (normal gas stations here in Colorado only sell 85, 87, and 91 octane fuel.) At that time I found out that they have to chip most of the cars that want more programs because the eprom in the older ECUsis too small to handle more than 1 program.
zero388 also mentioned before that he had an "older" TT in the orange headlight reflector thread..
Old Jul 19, 2007 | 12:11 PM
cincyTT's Avatar
I'm make believe
I summed that up when i said this...
ORIGINAL: cincyTT
that includes ALL 2000's and some early model '01's. Flashing is not really an option for these cars which sucks if you want to swap chips from stock to BT. I have heard horror stories about companies like upsolute chips being installed really bad and ruining ecu's.
archangel1st
Apr 12, 2023 08:50 AM
Pablo_Ottawa
Feb 28, 2009 10:06 PM
Mya4T
May 29, 2007 02:18 PM
JP A4
Dec 31, 2006 07:32 PM
