Somebody has plans for the weeked...
Old Mar 30, 2007 | 01:36 PM
MeanAudiA6's Avatar
Default RE: Somebody has plans for the weeked...
looks pretty cool where did u hear of this at? lets see some pics of the install on that one....are you gonna remove the oem flat black piece,pressure regulator?
Old Mar 30, 2007 | 02:18 PM
XCLR8TT's Avatar
No, that piece stays in. this just goes in between the PCV Valve and the intake.
Old Mar 30, 2007 | 02:31 PM
MeanAudiA6's Avatar
i read the pdf looks pretty solid....i did the air compressor catch can and it seems to be working great. though the rate i'm filling the can i might have to change it out every 1000 miles or so
Old Mar 30, 2007 | 02:42 PM
XCLR8TT's Avatar
You should probably replace your PCV valve. It's a bitch to get to, but if that isn't working properly, you'll blow by a lot more oil than you should.
Old Mar 30, 2007 | 02:47 PM
Indiepunk's Avatar
That is a manifold right? I saw a mod on Fotki where the owner polished the metal smooth. It looked a million times better than the stock finish. Just an FYI for the ambitious.
Old Mar 30, 2007 | 02:53 PM
techbod's Avatar
ORIGINAL: Indiepunk
its called port and polish mate or match bore and the results are impressive and its an inlet/intake manifold
Old Mar 30, 2007 | 02:54 PM
XCLR8TT's Avatar
That's today's project. Time to dig the Dremel out and go to it.
Old Mar 30, 2007 | 03:24 PM
  #18
MeanAudiA6's Avatar
did you order the brake painting kit from thettshop? i;ve had mine now(black with white rings) and have been waiting to do them for quite some time
Old Mar 30, 2007 | 03:36 PM
  #19
techbod's Avatar
Default RE: Somebody has plans for the weekend...
http://images.google.co.uk/images?hl...rite&gbv=2
hammerite smooth is best and a third the price and lasts longer
Old Mar 30, 2007 | 03:48 PM
  #20
MeanAudiA6's Avatar
has anyone painted their engine head? i would think the caliper paint would hold up to the heat. i think that would look pretty cool if painted all black....of course you would have to sand the head pretty good
