Squeaky suspension...
Old Apr 29, 2007 | 08:40 PM
neur0tic's Avatar
Default Squeaky suspension...
I use my 2001 TTQ 225 as a daily driver and the drive to work each morning has about 8 speed bumps on the road from my house. I've noticed that something creaks or squeaks pretty loudly as I go over them. I don't go over them fast or anything. In fact, the faster I go over them, the less I hear the sound.
I can best describe the sound by comparing it to the creaking door sound at the beginning of the song "Thriller". Maybe not a 2 second duration though. What would this be? I don't even know where to start. hmm
Old Apr 29, 2007 | 09:09 PM
XCLR8TT's Avatar
Default RE: Squeaky suspension...
Swaybar bushings most likely.
Old Apr 29, 2007 | 09:32 PM
neur0tic's Avatar
Tough job?
Old Apr 29, 2007 | 11:25 PM
XCLR8TT's Avatar
The rears are easy, but the fronts are a Beeotch. You can get new poly bushings from TTStuff or ECSTuning. IIRC the front requires unbolting the cross member. The rears you simply have to drop the muffler and the heat shield then 4 bolts to remove the brackets and two nuts at each rear wheel on the links.
Old Apr 30, 2007 | 01:02 AM
neur0tic's Avatar
I was thinking of going with poly bushings all the way around and the DEFCON system from modshack. If I get DEFCON 1, do I still need all 14 bushingsfrom TTstuff? Additionally, I recently got the 21mm rear sway from tCarbon. I havent received it yet though. Hoping to get it here this week.
GregL
Mar 18, 2010 09:58 PM
SF Audi guy
Sep 28, 2008 08:38 PM
evl6096
Nov 30, 2006 10:24 PM
InsaneHatter
Jul 8, 2005 12:42 AM
razgabor
Jun 27, 2005 09:28 PM
