trip meter
Old Apr 28, 2007 | 08:01 PM
gitargrl's Avatar
Default trip meter
my battery went dead I had it jump started but now I cannot figure out how to get the trip meter to stop blinking - 0:00h - any suggestions? the reset button doesn't seem to work it is a 2005 TT quattro with about 1000 miles on it thanks
Old Apr 28, 2007 | 08:29 PM
AudiOso's Avatar
Default RE: trip meter
On the underside of the wiper switch stalk there is a button labeled "Reset." Try that. I think that will solve your problem.
Old Apr 28, 2007 | 09:33 PM
achTTung's Avatar
no, if you're resetting the time, you'll need to pull the stick on the left, next to the display you want to set. That should put it into 'set' mode, and then twist it to the right to cycle thru the hrs. Another pull switches to minutes, and so on down thru the date. Once you get the year set, one more pull will make the whole date flash, and then you're done.
Old Apr 29, 2007 | 01:53 AM
gitargrl's Avatar
thank you for your reply I have tried the reset button and the pull on the left neither seems to work any other suggestions?
Old Apr 29, 2007 | 11:02 AM
AudiOso's Avatar
My bad... I thoughtyou weretalking about the display in the center of the dash where the average speed, mpg and trip time are displayed. You need to pull the trip odometer **** out to put it into time set mode.
Old Apr 30, 2007 | 02:34 AM
achTTung's Avatar
should be the stick on the left. I confirmed with my car. Pull and hold for 1-2 seconds, the hr should start flashing.
A4driver17
Jan 27, 2012 08:10 PM
TaysB5
Mar 11, 2008 10:25 PM
matthias2986
Apr 23, 2007 11:27 AM
cstarky15
Mar 8, 2007 02:15 PM
707782y
Mar 16, 2006 01:45 AM
