Tach problem on a '02 TT 225
Old Oct 13, 2006 | 04:04 PM
stitchy's Avatar
Default Tach problem on a '02 TT 225
Hi all,
I've got a 2002 TT with 45K miles. When I start the car, the tach needle jumps up and down like it's on crack. When I'm driving, if it's not jumping, it's really low, like 500 RPM at 50 mph. When I give it gas, it'll jump up. Is this the dreaded "lazy tach" problem?
All the other gauges (speedo, fuel, temp) are ok. The problem used to go away after a mile or two, but now it's staying like that longer and longer. I read the boards and some said it may be a battery problem, so on two separate occassions I put a battery charger on it overnight, but no dice.
So as you can tell, I'm trying my hardest not to have to replace the whole cluster because it's $$$ (but actually might not be a bad thing, it's also fading) Other than taking it apart and messing with it or buying a used cluster, is there anything else I can try?
Thanks for any help or advice you can give!
Old Oct 13, 2006 | 04:11 PM
techbod's Avatar
Default RE: Tach problem on a '02 TT 225
I cant find the link but I believe its some thing to do with the ABS ECU the site is BBS
rustyleskiv
Oct 13, 2019 07:29 PM
Tzar177
Apr 20, 2011 11:07 AM
H8URV8
Oct 31, 2009 07:49 AM
Lockloven
Jan 2, 2007 08:15 PM
GraffixWB
Nov 30, 2005 06:11 PM
