Tach Problems
Old May 18, 2007 | 07:30 PM
sheepcan's Avatar
Default Tach Problems
So I'm at a stop light and I take off and shift at like 3 grand and my tach doesn't go back down it just stays at 3, then when I'm in second it goes to like 6 and stops. So now my tach is stuck all the way back around to zero. What is wrong, I'm guessing it will probably cost me. Thanx.
Old May 18, 2007 | 07:55 PM
ouTTie914's Avatar
Default RE: Tach Problems
Your clutch could be slipping, or your cluster is shot. Not sure which one is cheaper....
Can you start your car? If not start looking at clutch kits.
Old May 18, 2007 | 07:59 PM
sheepcan's Avatar
Its not my clutch, the engine doesn't rev or anything the tach just sticks.How much is it for a new cluster and who can put that on?
Old May 18, 2007 | 08:14 PM
ouTTie914's Avatar
The engine DOESN'T rev, and you think it's the tach.... I must of missed something here!
Old May 18, 2007 | 08:18 PM
sheepcan's Avatar
The car drives normal my tach just jumps around, I'm sorry I miss read your other thread, I'm sure it's my cluster do you know how much it cost and who has to do it?
Old May 18, 2007 | 08:33 PM
cmh's Avatar
cmh
Repair- $250-$400 you pull it out/send it in. $1000 Dealer installs new "upgraded" cluster. My dealer covered half the cost so I paid $500 to get a new cluster @ 104 K. The cluster issue is a known weak point of the TT, and once one gauge starts acting up it only gets worse from there, sorry
Old May 19, 2007 | 06:46 AM
neur0tic's Avatar
When he revs the engine... the tach goes up but doesnt go down... when he releases the gas.. the engine does slow down... the tach just does not reflect that.
Old May 20, 2007 | 12:44 PM
foxrcng11's Avatar
my tach hasnt worked for over 6 months... im fighting it with audi but they suck lol.... im fixing mine through bba-ramen or whatever theyre called for $250but you gotta mail it to them and you cant drive the car w/oit so get something to drive while its being fixed
Old May 20, 2007 | 12:50 PM
techbod's Avatar
check for recalls ( its a sticky needle ) the spring is weak or the dash got too hot and expanded making the needle stick but as its electronic it could be the VSS or ABS because they are linked but ill go for a sticky needle
srlito
Jul 8, 2009 12:45 AM
98a6at2.8
Mar 26, 2009 02:52 AM
reyflex
Jan 13, 2007 06:20 AM
Lockloven
Jan 2, 2007 08:15 PM
stitchy
Oct 13, 2006 04:11 PM
