tail light diy
Old Jan 26, 2010 | 03:12 PM
NaudifreakTT's Avatar
Default tail light diy
has anyone seen a diy for removing TT tail lights?
Old Jan 26, 2010 | 04:07 PM
OmniEnder's Avatar
First remove the panels in the rear side of your cargo area.
Inside there are two hand screws that secure the tail lights.
One you will be able to see, it is directly in, the other you will not be able to see and will have to find by feel, it is located up at the top of the interior of the opening.
Those are all that holds the light assembly to the car. The lights themselves are twist disengage, a quick twist to disconnect the bulbs and your light assembly is out.
Hope that helps
Old Jan 26, 2010 | 06:58 PM
warranty225cpe's Avatar
There are also 2 round tipped metal bolts that pop into a little socket on the other end of the tail light(one on each corner).
Old Jan 28, 2010 | 05:20 PM
infurce09's Avatar
Banned
Yeah. Theres gonna be 4 bulbs for the running lights. The 2 most outter & the 2 middle ones on each tail light. Give that a shot & report back.
Also, are these OEM tails or aftermarket?
Old Jan 29, 2010 | 12:27 PM
MCPaudiTT's Avatar
pbrules10
Aug 2, 2011 01:22 AM
MagicHobo
Nov 14, 2008 01:37 AM
tsk
Apr 27, 2008 04:56 PM
audi ace
Jul 22, 2005 01:53 AM
