Taking a leak...
There is a drain there and behind the drivers door on the roadster.
Radiator fan issue -- Do your fans turn on when you turn the AC on? If so the fan control switch might be bad, if they dont turn on then you possibly have a bad fuse (the one on the far left on top of the battery box).
I actually noticed that when I got home yesterday, the car was running warm...I turned on the ac/heat, and the temp started to drop a bit...I have a major service coming up next weekend and they said they would look at it then if they had time.
Trinitylee
Feb 7, 2010 12:12 AM
