Tcarbon FMIC vs Forge Motorsport FMIC 180 HP Quattro
Old Aug 1, 2007 | 08:20 AM
  #91
DurTTy's Avatar
Default RE: Tcarbon FMIC vs Forge Motorsport FMIC 180 HP Quattro
nice pics! i personally preffer silicon hosing over shinny aluminum. but thats just me. still a clean setup, but the FMIC still look a little smaller tell you the truth.
Old Aug 1, 2007 | 01:22 PM
  #92
DurTTy's Avatar
what are the dimentions of that FMIC ... (side note: bracket construction, yarg!!! i really hate any form of welding if required.)
Old Aug 1, 2007 | 01:33 PM
  #93
cincyTT's Avatar
I'm make believe
Core length : 24"
Core height : 9"
Core thickness : 2 3/4"
Inlet/Outlet size : 2 3/4"
There was no welding. He just got a long peice of aluminum and cut it into 3 strips and 6 bolts to support the core.
Here is his new thread
Old Aug 1, 2007 | 01:42 PM
  #94
DurTTy's Avatar
one quick question Where is the DV????I think he relocated the DV, correct me if im wrong.
Old Aug 1, 2007 | 01:46 PM
  #95
cincyTT's Avatar
I'm make believe
same place, just where it goes is changed. Its just covered with the recir hose and the bend that goes over it.
Old Aug 1, 2007 | 01:52 PM
  #96
cincyTT's Avatar
I'm make believe
this guy has it "reversed" and done better, but same kit
Old Aug 1, 2007 | 02:41 PM
  #97
zero388's Avatar
I have heard that it is better to have metal ic pipes rather than silicone because the silicone ones tend to flex. Is this true or does it not really make a difference?
Old Aug 1, 2007 | 02:51 PM
  #98
DurTTy's Avatar
the silicone pipes are more heat resistant, and the proper silicone hoses have re-inforcements which prevent flexing. tey are actually quite stiff and hold up a lot more pressure than one thinks.
(they are not as soft as the wifes ***** [sm=happy046.gif])
Old Aug 1, 2007 | 03:37 PM
  #99
cincyTT's Avatar
I'm make believe
The aluminum can also transfer heat better than silicon. It can draw out some of the heat in the charge pipe.....unfortuatly, it can absorb heat from the engine aswell.
Old Aug 1, 2007 | 08:00 PM
  #100
DurTTy's Avatar
win some u lose some ... its up to personal prefference.
im gonna grab the tcarbon setup when i come back from vacation, should be a good setup. ill make sure i get lots of pick
