temp gauge
Old Jan 24, 2007 | 02:38 PM
dtcoastguard's Avatar
Default temp gauge
Hey I just wanted to see if anyone had anything like this in the past. On my drive home from work last night I noticed that my temp gauge was higher than normal. It normal is just slightly past the half way line on the gauge(1200 clock postion) Now it is slightly past the next line to the right toward the "H" side. It was 39deg. F outside so it wasn't hot conditions.I noticedthe nextmorning when I got upto go to work that theTemp Gauge when I stuck the key in the ignition was oneslightlyrightof the firstline up past the the bottome lineon the Cold side. It seems to be inline with the higher normal temp when at operating the car. Has anyone seen this, I hope that it is an indication problem and not a serious problem. I was going to hook up a digtal temp cauge on one of the raditor hoses and see what the temp. is. What should I look for on those temp. Numbers at normal operation temp. Thanks guys Dmitry
Old Jan 24, 2007 | 03:10 PM
XCLR8TT's Avatar
Default RE: temp gauge
Check the climate control diagnostic mode first... See what channels #49 and #51 are showing..
Old Jan 24, 2007 | 03:35 PM
Inimical's Avatar
lol, join the club!
Is it me or are we seeing a bunch of posters complain about their gauges in the last few days?
I would verify the true temp as per xclr8tt's post just to be sure though. Then, when you're done with that, come vote in the Poll someone else posted a few days ago. https://www.audiforums.com/m_439649/tm.htm
Old Jan 24, 2007 | 04:20 PM
I did the climate control diagnostic mode ... See what channels #49 and #51 One 49 at running temp it was 86 Deg. C and I didn't do #51 What is that temp tell me on 51# it says that #49 is more accurate......Dmitry
Old Jan 24, 2007 | 10:42 PM
XCLR8TT's Avatar
Channel 51 is a time averaged number or something along that line.
Sounds like you may have a bad temperature sensor. Pick up the Green one and install it like this.
zedea
Jan 18, 2013 03:11 PM
Russell2686
Jul 8, 2009 11:55 AM
dhillon
Feb 23, 2009 07:14 PM
theTTkid
Nov 7, 2007 05:52 AM
IDUA ORTTAUQ 6A
Oct 8, 2007 07:24 PM
