Temp gauge question
Old Oct 1, 2008 | 10:32 PM
MK1_TT_Quattro's Avatar
Default Temp gauge question
Hey guys, Just joined the forum and have a few questions.
Is it normal for the temp gauge to rise over half sometimes? I brought it in to the dealer twice for this and they told me this is normal. The gauge works perfectly my only concern is when i let the car idle for a few minutes the gauge will go over the half point but not to the end and as soon as i start driving it will go right back at half. Or sometimes its at half and i shut off the car, if i start it again 5-10 mins later it will be over the half point, and a few seconds later slowly go back to half. The audi mechanic told me this is normal because when i shut off the car the heat rises to the sensor.
I doubt this is normal my a4 1.8t never did this.
Ive read that the tt's are know for bad clusters but the dealer told me all the gauges are within spec.
BTW The car has a new water pump and temp sensor.
Old Oct 1, 2008 | 11:36 PM
ecko2702's Avatar
Im no Audi tech but I wouldnt worry mine does it to. If i leave it at idle it will slowly go up 1 bar on the gauge then back down even when its hot and i shut if off then turn it on again in 5 min the gauge is high.
Old Oct 2, 2008 | 10:40 AM
Mac_17's Avatar
Same thing with mine. I have never found the problem or the solution.
Old Oct 2, 2008 | 01:24 PM
Wintermute's Avatar
Mines doing that right now I'm thinking bad cluster.
Old Oct 2, 2008 | 01:43 PM
bvgoosedd's Avatar
mine does it too. lol damn that is alot of people. also i got a cooler temstate and now it goes both ways but it doesn't go toward hot unless i really get on her.
Old Oct 2, 2008 | 02:29 PM
theTTkid's Avatar
this has come up before, its not really of any conern... besides, if your car gets too hot itll let you know...
Old Oct 2, 2008 | 04:43 PM
bvgoosedd's Avatar
wait how will it let you know? when the engine blows or do you mean an idicator will come up
Old Oct 2, 2008 | 05:47 PM
jakej's Avatar
Mine never does or did and I just had a bad cluster temp gauge replaced. I would check your coolant sensor (make sure it's green or whatever). Another note: the temp gauge is NOT linear. One degree can move the gauge an entire notch.
Old Oct 2, 2008 | 07:36 PM
GHETTOxWHITExBOY's Avatar
when you turn off the car the coolant temp will rise....that normal. the coolant doesn't circulate like if the car was running and the airflow isn't there either.
zedea
Jan 18, 2013 03:11 PM
crazyquik22023
Oct 21, 2011 11:01 PM
Nevalite
Feb 4, 2011 01:28 PM
Russell2686
Jul 8, 2009 11:55 AM
Plopper
Feb 20, 2009 02:04 PM
