Terrible squealing
Old Nov 21, 2006 | 01:16 PM
  #21
Adam in CO's Avatar
Default RE: Terrible squealing
Fan clutch. You nailed it.
Old Nov 21, 2006 | 03:50 PM
  #22
XCLR8TT's Avatar
ORIGINAL: Adam in CO
No such thing in the TT.. Fans are electric.
Old Nov 21, 2006 | 04:22 PM
  #23
Adam in CO's Avatar
So, turning off the fan for ignition solving the problem is a coincidence?
Old Nov 21, 2006 | 05:48 PM
  #24
XCLR8TT's Avatar
Maybe not totally, the fans like so many other parts are prone to wear, it is possible that the noise is coming from the fan's nylon bearing.
Old Nov 22, 2006 | 12:58 PM
  #25
diehlryan's Avatar
I just bought my 2001 TT 180 Roadster Saturday. I have the same problem in the mornings when its cold. After driving for a bit the sound goes away when starting. Also if I leave it sitting in the sun it doesn't squeel either. It doesn't seem like this is a huge problem and I dont think I should be worried. Has anyone had any luck with getting this fixed by a dealer or mechanic?
Old Nov 22, 2006 | 01:40 PM
  #26
XCLR8TT's Avatar
That sounds like it may be the secondary air injection pump. It is a small belt driven pump that runs when you first start up for emissions reasons.
Old Dec 23, 2006 | 01:17 AM
  #27
VW01AUDI00's Avatar
If any one has found a resolution to this problem I have it to just on start up when cold sounds like a squealing belt for a second or two if I hit the gas it goes away . I just put a new cylinder head water pump and all new belts on the car 2000 a4 1.8Q . The small V belt from the water pump to the powerstering pump had slack on it I just cut it off and went to VW dealer for new belt might have been wrong belt but I'm still getting squealing on start up .I think its possibly the clutch fan or tensioner and the power stering pump was a couple oz.low on fluid .ssssssssooooooo aaaaaaaaaaaaa IIIIIIIII don't know.
Old Dec 23, 2006 | 02:28 PM
  #28
Adam in CO's Avatar
The mechanic has now replaced the belt and belt tensioner, the secondary pump, and the blower motor. Strike 3, you're out. It turned out to be the electric fan in front od the radiator making the noise. Lot's of free work from these guys, at least. I have all sorts of new parts that are meaningless in a car with 30k miles.
Old Dec 24, 2006 | 02:10 AM
  #29
VW01AUDI00's Avatar
Thanks Adam I'm going to replace my fan to start I'll replie when I do.
[sm=smiley23.gif]
Old Feb 18, 2007 | 02:17 AM
  #30
VW01AUDI00's Avatar
The noise is coming from my starter
cheapdA8
Jul 5, 2010 08:39 PM
orbit55
B7 Models
May 15, 2009 10:11 PM
ledzepp2994
Apr 11, 2009 02:40 PM
syedzadey
Mar 24, 2007 07:44 AM
joe4123
Apr 28, 2006 04:03 PM
