Three Codes- Three problems?
Hey everybody. I have had my cel on since I was running no cats. I got the apr program that disables the rear o2 sensor from throwing a code, but about a month ago i got a cel and had it pulled. It was the front o2 sensor. Ok, I just got a new exhaust system, with the cat back on, and still have the same code plus two more. Here are the three codes. Can anybody tell me, which i am hoping so, if they are related? For example, if one code is setting the other ones off?
P0036 H02S Bank 1 Sen 2
Heater Circuit
P0136
o2 sensor
Circuit Malfunction
P0352
Ignition Coil B
Primary / Secondary
Circuit Malfunction
Any help would be great. I have a new o2 sensor on the way.
Thanks in advance.
Heater Circuit
P0136
o2 sensor
Circuit Malfunction
P0352
Ignition Coil B
Primary / Secondary
Circuit Malfunction
Thanks in advance.
The first two are, replace the rear 02 like you are planning and that should clear them up, the last one is a bad coil duh, may want to look into getting that replaced. I know ecstuning.com has replacement ones that are supposed to be pretty good. Good luck.
