throttle position
Old Sep 21, 2019 | 05:51 AM
Jon Sanfilippo's Avatar
Default throttle position
i just recently bought a 2000 tt and it threw a code saying i have a bad throttle position sensor it lags in every gear around 3000 rpms it seems to not activate the turbo can anyone tell me where that part is located or they have had the same issue?
Old Sep 22, 2019 | 01:13 AM
MoneyPiTT's Avatar
You'll have to replace the throttle body most likely. I would buy a Bosch brand if it turns out to be that. They make the part for Audi. Without a lap top and VCDS, or a VAS5052 scan tool I wouldn't know how to properly test to see if it is the throttle body. If you know someone with a high quality scan tool they probably could test it for you to confirm it is the throttle body.
The only issue with replacing the throttle body is that you have to perform a throttle body alignment with a scan tool after you install a new throttle body.
george1546
Sep 10, 2013 03:20 AM
chowmouse
Jan 27, 2011 03:40 AM
kraylon
Sep 2, 2009 09:32 PM
audirpm
Mar 25, 2009 09:35 AM
1quicka4
Jul 17, 2007 06:35 PM
