transmission problem
Old Feb 7, 2009 | 08:42 PM
andres85tt's Avatar
Default transmission problem
I have an 03 TT with 72000 miles. Everything was fine, it ran great, pulled into my garage, turned it off, the next time I got in. . .no 1st or 2nd gear. Unbelievable, I NEED help Thanks!!!
Old Feb 7, 2009 | 09:22 PM
myslow1's Avatar
define no first or second gear... Were you having problems with it before? Like was it hard to get in or out of those gears? 1-2 should be on the same syncro but if you had 0 problems i doubt that problem would just magically appear. Can you not get it go go into those gears or can you put it in but nothing happens?
You can try checking your shifter linkage? But if that were the problem you would have issues in all gears.
Old Feb 7, 2009 | 09:29 PM
andres85tt's Avatar
no problems before. it will go in to the 1st n 2nd but it will not move. i had to drive it in
3nd just to move it out of my driveway. so i dont know whats going on.
Old Feb 7, 2009 | 09:39 PM
myslow1's Avatar
I cant imagine you just losing 2 gears... Hopefully it is something simple to fix. Im sure someone with more knowledge about trannys will chime in.
Old Feb 7, 2009 | 09:42 PM
andres85tt's Avatar
thanks!!
Old Feb 8, 2009 | 12:08 AM
mspryor's Avatar
my 97 A8 has gone into what they call a fail safe mode which doesn't shift. Do you have dash lighted gear selection display. If so are all the gears lit up?
Old Feb 9, 2009 | 02:34 AM
myslow1's Avatar
bump for him to get an answer
Old Feb 9, 2009 | 03:42 AM
Murderface's Avatar
First, check the shift linkage. this is under the intake. If it's loose or disconnected, it's an easy fix. Have someone see if it's moving when you shift into first/second. If it's moving normally...then the fun begins.
My guess is if it's not in the linkage, the 1st/2nd gear shift collar is off of the shifter fork for some reason or another.
Old Feb 9, 2009 | 12:19 PM
andres85tt's Avatar
that was i was thinking too. n i hope thats what it is. i just took the car to the mechanic. he said that he would let me know in the afternoon. thanks for ur help man..
mason13
Aug 24, 2013 03:43 PM
unnaturallyaspirated
Jun 20, 2013 08:14 PM
miminan
Nov 7, 2010 09:57 AM
wildgene789
Jun 29, 2008 07:27 AM
