Trunk Lights don't Work?
Old Oct 29, 2008 | 07:41 PM
joshuo's Avatar
Question Trunk open sensor???
Hi all.
My trunk lights don't seem to work. (trunk open, lights on)
You know, the one near the warning sign (don't smash people's heads in) in the hatch,
and the one on the left side of the trunk, near where the Amp is?
I checked the bulbs and they are fine.
Fuses seem ok.
What is going on?
Last edited by joshuo; Oct 30, 2008 at 07:13 PM. Reason: Problem is not with the lights.
Old Oct 29, 2008 | 08:10 PM
joshuo's Avatar
Update:
I found the culprit.
The car doesn't 'know' that the trunk is open.
Faulty microswitch? where is it located?
thanks
josh
Old Oct 29, 2008 | 08:30 PM
myxyzxo's Avatar
SoCal Crew Member
Mines doesn't come on either. Unless I turn the hazard lights on.
Old Oct 30, 2008 | 12:48 AM
myslow1's Avatar
i just noticed i had trunk lights today... mine dont come on either. I was going to check it out tm
Old Oct 30, 2008 | 01:06 PM
hotgrass's Avatar
mine too
Old Oct 30, 2008 | 01:25 PM
myxyzxo's Avatar
SoCal Crew Member
Open trunk, then turn on hazard lights. They should come on.
Old Oct 30, 2008 | 05:03 PM
joshuo's Avatar
^ nope, I tried that. It wouldn't make sense anyway.
Why would you need the courtesy lighting in the trunk ONLY when the hazards are on?
For those people with the same problem, when your trunk is open, does your HUD say 'trunk open'? I'm pretty sure it should.
That leads me to believe there is a microswitch in the lock that is stuck on 'closed'.
Yay, Nay?
Where is it?
epiphysis
Jul 25, 2011 11:47 PM
stuck amals
Dec 28, 2010 06:29 PM
MartinCieslak1
Sep 30, 2010 02:26 PM
gioinnj
May 6, 2010 10:32 AM
exequiel3k
Sep 13, 2009 05:47 PM
