TT 225hp Engine Oil for the Track
Old May 26, 2010 | 02:31 PM
kjohn944's Avatar
Default TT 225hp Engine Oil for the Track
Hey fellow TT'rs
Any recommendations for engine oil weights & type to use when running the 2002 1.8L HO 225hp engine on the track (i.e. high performance driving). Sessions tend to be aprox. 20 minutes in length and 4 a day. I plan to be flat out when I can.
Thanks!
Old May 26, 2010 | 04:11 PM
cincyTT's Avatar
I'm make believe
same oil. You may want to move to a larger Passat/A4 oil filter which will hold more oil
Old May 27, 2010 | 08:29 AM
kjohn944's Avatar
Thanks Cincy. From what I've seen on the other oil weight threads in this forum I'll stick with Mobil 1 0w40 synthetic as the 502 spec from Audi. I was wondering about stepping up to a w50 for the track but haven't seen anyone try it. Besides, it doesn't look that weight is on the Audi approved list of oils anyway.
Makes sense to use a larger oil filter, but the one spec'd for the TT is a royal pita to get out. Will the larger A4 filter fit ok in the TT?
zahnbe
Jan 14, 2021 11:19 AM
JeanValjean
Sep 2, 2014 10:31 AM
a2thy
Mar 15, 2009 04:31 PM
showurtt
Mar 13, 2007 12:52 AM
