Tt quattro 225 upgrades?
Old Jun 17, 2010 | 12:06 AM
Colombian's Avatar
Are they expensive
Old Jun 17, 2010 | 04:08 AM
neur0tic's Avatar
I don't know how mechanically inclined you are... and if you have any experience doing turbo work.. but the FMIC is a pretty easy install... but the turbo itself will cost you quite a bit in labor; you might wanna set aside at least $800-$1,000 for labor if you don't plan to do the work yourself. Otherwise, I agree with Nate. But if you set aside the $1k for labor... you can easily get a big turbo kit for under $4k
the problem you'll have tho... is that if you blow your whole wad on the turbo kit... you'll end up with a ton of power and lacking the braking ability to safely stop your car once you get it really moving.. and thats extremely dangerous.
I ALWAYS recommend that before adding more than 100-300HP to your car... you should definitely upgrade your brakes first, your cooling (intercooler), and strengthen your suspension. The worst thing you can do is create a Super rocket car that you cant control or stop. You really don't need to do a ton on the suspension, but I'd say polyurethane bushings... and sway bars are almost a must... otherwise you'll roll the damn thing the first time you try to turn at speed... and since you wont have the brakes to slow down before turning... you'll HAVE TO turn at speed. So yea... at least one or the other... if you cant strengthen the suspension to prevent rolling... then at least upgrade the brakes so you wont have to turn at such high speeds.
Old Jun 17, 2010 | 05:04 PM
Colombian's Avatar
If I was to get the apr turbo kit how much do you think a shop will charge me to put it in
Old Jun 17, 2010 | 05:30 PM
neur0tic's Avatar
Where do you live??
If you live anywhere near Alabama/Georgia, you can just go to the APR shop and let THEM put it in.
Old Jun 17, 2010 | 05:55 PM
cincyTT's Avatar
I'm make believe
So you have $5k to spend and you want to buy a $7k turbo kit AND have it installed? My math may be off but isnt 7 > 5?
A 50trim kit from pagparts is around $3500 for everything. Add in a fmic $500-1k and another $500 or so for an install if you cant do it. hhhhmmm Mild 20psi will get you ~300whp, build the motor and add other parts and 350-375whp is doable on pump and 425-450whp on race gas is doable
Old Jun 17, 2010 | 06:34 PM
Colombian's Avatar
I'll wait a month and I'll have 8 or 9 grand total
Old Jun 17, 2010 | 07:19 PM
cincyTT's Avatar
I'm make believe
still go with pagparts, apr is overpriced and underperforms
Old Jun 17, 2010 | 07:28 PM
  #18
neur0tic's Avatar
wow... $3500 is a good price.
Wonder what he'd ask for a T30 gt3071r setup, including downpipe?
Old Jun 17, 2010 | 07:49 PM
  #19
cincyTT's Avatar
I'm make believe
Just do the drop downs on the website.
Old Jun 17, 2010 | 07:58 PM
  #20
neur0tic's Avatar
what website?
I went to pagparts... but I didn't se any drop downs..
